MAX 10 Projamming Issue 10M25SCE144I7G
Hi INITDONE,
Have you tested it (the .jam file) on another Max 10 device? What's the behavior?
Try to make a new simple design, generate it into a .jam file, and try to configure it.
fakhrul
- INITDONE3 years ago
Hi Fakhrul,
Thanks for the Reply.
We have only one Max10 device is there and made very simple design with 11 IO pins , just loop test only.
Tried with SOF and POF and JAM file but all file are showing same error and error is below,
Error(16353): Expected the Max 10 device at index 1 to be of type analog, but detected device of type compact instead. Ensure that you are using the correct programming file.
configuration scheme is Internal Configuration
Configuration mode : Single compressed Image (3200Kbits UFM)
still not able to resolve the Issue. Please help us
Thanks & Regards,
Ramesh S
