Max 10 Pin Compatibility
Hello Community,
I can use in my design either 10M04DCF256A7G or 10M08DCF256A7G. They are pin compatible. But what if I want to use the other members of the family like 10M16DCF256A7G, 10M25DCF256A7G or 10M50DCF256A7G in the same design. Are they still pin compatible? According to the datasheet there are 3 pins that are different. In case of 10M04DCF256A7G and 10M08DCF256A7G they are unconnected hence my design has no connections at these pins. The other family members has connections/functionalities at these pins. But what happens if they are unconnected?
P.S.:
- 10M04DCF256A7G and10M08DCF256A7G are just unavailable. I need to find other solutions.
- I need 4000-6000 devices per month.
Thanks a lot for the answers!
Hi FPGA,
As long as they fall under the same package it shouldn't be a problem.
You can refer to the Migration Capability Across Intel MAX 10 Devices on page 8 in the following document:
Intel® MAX® 10 FPGA Device Overview
Fakhrul
- FvM
to be sure not to overlook any necessary connection in migration compatible devices, I'd proceed as follows
- select all intended migration devices in your Quartus design
- place a top level entity with all port signals and signal direction- optionally add basic functionality for dedicated signals (PLLs connecting to clock in- and outputs, SERDES IP)
- assign locations and IO-standards for all signals
- compile the design- review the required connection in generate .pin file. You particulary find all pins needing connection to GND or supply voltage for migration devices
Frank
- FakhrulA_altera
Hi FvM,
As long as there's no error nor significant warning during the compilation process, plus with all your mentioned procedures above, it should be no issue.
Fakhrul
- FakhrulA_altera
- FakhrulA_altera
Hi FPGA,
Fakhrul
