MinzhiWang
2 years agoMax 10 pin assignment issue
Hello Guys, We are using Max 10 device, the part number is "10M25DAF484C7G". Our Quartus version is 23.1std.0991 standard edition. There are several ADC input buses which are connected to Max 10. H...
- 2 years ago
You have signals named incorrectly (OUT vs. Out). You should not enter signal names manually in the Pin Planner. They will appear there after Analysis & Elaboration so you can select location and other I/O-related assignments.
sstrell
2 years agoYou have signals named incorrectly (OUT vs. Out). You should not enter signal names manually in the Pin Planner. They will appear there after Analysis & Elaboration so you can select location and other I/O-related assignments.
- MinzhiWang2 years ago
Hi sstrell,
Yes, you are right. We apply constrain thru TCL script files. The pins assignment include two parts, however, the two groups assignment names have tiny difference. So Quartus takes them as two different objects.
Thanks for you remind.
