9 years agoMax 10 IO status when Jtag Programming
Hi there, I use Max 10 10M04DAU324 Series FPGA in our design. Only I konw that IO status keeps tri-state with internal weak pull-high when CFM to SRAM(config mode) as attachment picture sh...
9 years ago --- Quote Start --- In a normal ISP operation, to update the internal flash with a new design image, the device exits from user mode and all I/O pins remain tri-stated. --- Quote End --- Whenever the device is not in user mode all I/O are tri-stated. This includes when the device is being configure via JTAG. See the 'max 10 fpga configuration user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/ug_m10_config.pdf)'. Cheers, Alex
