10 years agoMAX 10 FPGA_ Device Selection Help
Hello All, Does Max 10 FPGA series support Ethernet core?. I am thinking of using a max 10 FPGA part number - 10M50SFE144I7G....But, I couldn't find if I would be able to use an Ethernet core with...
10 years ago --- Quote Start --- Hello All, Does Max 10 FPGA series support Ethernet core?. I am thinking of using a max 10 FPGA part number - 10M50SFE144I7G....But, I couldn't find if I would be able to use an Ethernet core with it. Please advice. Thanks, Manoj --- Quote End --- What variation of etherNet? 10Mb, 100Mb, 1Gb, 10Gb? The requirements are very different depending on your performance requirement. What physical interface to you intend to use as well? 'Standard' transformer coupled RJ45 style, with an external PHY, or some other means (like SERDES)? Are you planning on using some kind of development board, or is this a custom PCB design? The more specifics you can provide in your post the better the responses will be.
