Max 10 doesn't start
- 5 years ago
Fix it, It was problem of the quartus when it created the file. I don't know why...
Hi, it is not starting with a proven design? After programming and or at power up?
Try a simple design can be tested on board, IE an LED connected to JTAGEN, generate and load as SOF without programming Flash.
Test Config_done and nConfig level, if not High test all other configuration input for high level.
In case of failure try add 4 more resistor + 1 cap:
10 KOhm pullup to CRC err (known) TDI TMS (less importance)
1 KOhm pullDOWN to TCLK (Possible caveat)
10-100 nF cap from CLR_n to ground
- RRomano0015 years ago
Contributor
I cannot modify message...
About CRC Error, I checked two of my design, is connected to logic without pullup.
Please try verify flash and tell us about what is on console.
From what I remember I got troubled by some pin driving nConfig, ConfigDone, nStatus, are these pin free on your design or shared to?
