Raydem
5 years agoMax 10 doesn't start
Hello, I have a problem with the max 10. I have programmed it in the flash memory the code, but I am not able to start the FPGA. I leave you a part of the schematic of the configuration pins.
- 5 years ago
Fix it, It was problem of the quartus when it created the file. I don't know why...
NurAiman_M_Intel
5 years agoHi,
- Max 10 does not need to power cycle.
- Try to check your design: pin connection, IP address, etc..
- Try a simple design such as LED blinking and see if the LED is blinking or not. If yes, that means there is no problem with your Max 10.
Let me know your concern.
Aiman
