10 years agoMax 10 DDR Memory Interface Support
I am currently working on a new design where I'd like to integrate a 10M08DCU324C8G Max 10. I'd also like to have some DDR3 memory on board as well, so I've been looking into the IP cores that Altera...
10 years agoThe 10M08 device won't support a DDR3 memory interface.
Running the Quartus generated ddr3 interface example through results in the following errors: --- Quote Start --- The design contains 8 blocks of type "Double data rate I/O input circuitry" but the selected device 10M08DCU324C8G does not support such blocks The design contains 1 blocks of type "I/O Clock Divider Circuitry" but the selected device 10M08DCU324C8G does not support such blocks The design contains 1 blocks of type "PHYCLK Tree" but the selected device 10M08DCU324C8G does not support such blocks The design contains 1 blocks of type "Phase Detector" but the selected device 10M08DCU324C8G does not support such blocks --- Quote End --- However, change the device and everything fits in the 10M16DCU324C8G. Cheers, Alex
