MAX 10: Can an ASx1 RBF be written directly to internal CFM via on-chip flash Avalon-MM?
- 2 months ago
Hi raulp,
MAX 10 CFM can be updated from user logic through the On-Chip Flash IP, but an ASx1 .rbf is not the recommended direct-CFM image. Generate the MAX 10 Raw Programming Data (.rpd) through Convert Programming Files, and use the .map file to identify the correct CFM data and address. Do not write the complete RPD blindly from address zero because it may contain ICB, CFM, and UFM data.
The update sequence should include erase/unprotect, status polling, the required per-byte bit reversal, and readback/CRC verification. For dual configuration, preserve CFM0 as the factory image and update CFM1/CFM2, then use the Dual Configuration IP to reconfigure.
The I2C Slave-to-Avalon-MM Master Bridge is not needed if UART/user RTL already provides an Avalon-MM master. It is required only for an external I2C-controlled update path.
Please use AN 741, Remote System Upgrade for MAX 10 FPGA Devices over UART with the Nios II Processor, as the primary reference and validate the exact device configuration and CFM addresses on a spare board first.
Fakhrul
MAX10 doesn't use AS configuration or .rbf files. Raw binary files that can be directly written to CFM memory have .rpd file type. The best way to perform remote update with MAX10 is using dual configuration scheme, but I don't know if your application has sufficient flash to implement it. It's possible to rewrite single configuration flash in user mode, but there's no fallback mechanism. You can however read back image or perform a CRC check before rebooting.
Regards Frank
