10 years agoMax 10 Bank 8 set 1.2V ?
I am working on a project with the Max 10, specifically using the Arrow Deca kit, which has a 10M50DAF484C6GES. I am working on a video project, but I am having a simple pin assignment issue that I do not understand. The Deca kit has a bank of 8 leds. According to the schematic and example projects, the leds are assigned to certain pins on bank 8 at 1.2V. The example project succesfully compile the Start IO command (and the Start compile comand). However, when I try to run Start IO with my project, I get errors (see attached) regarding the voltage level of bank 8. As far as I can see, I've assigned the pins in Pin Planner exactly the same way they are in the example project (I've copied from mipi_hdmi project), and there is nothing else on Bank 8 except those LEDs. I'm not sure why my project is having an issue with the voltage, and the mipi_hdmi is not. Thank you for any advice, or for any documentation or tutorials I should pursue to understand.1 Reply
based on certain advice I found on the forumns, I went to Assignments>Device>Device and Pin options> General and unselected Auto-restart configuration after error Enable nCONFIG, nSTATUS, and CONF_DONE pins Enable CONFIG_SEL pin to match the example mipi_hdmi project. This fixes the error that was showing up in my project (though to be honest, I don't understand why). Thanks
