11 years agoMax 10 ADC Simulation - Can't get it to work properly
Hi all, I'm trying to simulate a MAX 10 design using the internal ADC before I get real hardware and I'm only having partial success. I've now produced my own design and experimented with ...
11 years agoThanks irish but that vid doesn't mention simulation at all.
I've now got real hardware and can confirm that the simulation doesn't drive the response signals at all though I am setting the ADC up correctly. To get around my simulation issue I wrote the following. Maybe it is of use to somebody. It is in noway functionally complete.module ADCModel (
input clock_clk,
input reset_sink_reset_n,
input adc_pll_clock_clk,
input adc_pll_locked_export,
input sequencer_csr_address,
input sequencer_csr_write,
input sequencer_csr_writedata,
input sequencer_csr_read,
output reg sequencer_csr_readdata = 32'd0,
output reg response_valid = 1'd0,
output reg response_channel = 5'd0,
output reg response_data = 12'd0,
output reg response_startofpacket = 1'b0,
output reg response_endofpacket = 1'b0
wire go = reset_sink_reset_n && adc_pll_locked_export && sequencer_csr_readdata;
always @ (posedge clock_clk) begin
if (sequencer_csr_write && !sequencer_csr_address) begin
sequencer_csr_readdata <= sequencer_csr_writedata;
end
end
localparam NUMBER_OF_CHANNELS = 5'd4;
reg adc_clk_store = 2'd0;
wire response_channel_next = (response_channel >= NUMBER_OF_CHANNELS - 5'd1) ? 5'd0 : response_channel + 5'd1;
adc_clk_store <= {adc_clk_store, adc_pll_clock_clk};
if (go) begin
if (adc_clk_store == 2'b10) begin
response_valid <= 1'b1;
response_channel <= response_channel_next;
response_startofpacket <= (response_channel_next == 5'd0);
response_endofpacket <= (response_channel_next == NUMBER_OF_CHANNELS - 5'd1);
case(response_channel_next)
5'd0: response_data <= 12'h111;
5'd1: response_data <= 12'h222;
5'd2: response_data <= 12'h333;
5'd3: response_data <= 12'h444;
endcase
end else begin
response_valid <= 1'b0;
response_channel <= 5'd0;
response_data <= 12'd0;
response_startofpacket <= 1'd0;
response_endofpacket <= 1'd0;
end
end else begin
response_startofpacket <= 1'b0;
response_endofpacket <= 1'b0;
end
end
endmodule
