14 years agoMatrix Adder
Hello, I have one captious question. I need to buil-up matrix adder. Totally 1920x1080=2073600 cells able to do three different operations with 24bit integer value: 1/ A+B=C 2/ A-B=C ...
14 years agoThat is NOT the way you need to look at it.
Like DSL said, you will NOT be processing the image as a matrix, you will be treating it as a linear stream of data, 1 pixel at a time. So you would only need very few luts and reigsters to do the adition or subtraction. There is no way any of the FPGAs have enough internal memory to store a single HD frame, let alone 1000s. You will be proceing the data as it arrives. I suggest you go and learn up about digital logic before you move forward. You are completly misunderstanding the architecture of FPGAs.
