18 years agomatlab to nios ide
Hello, i am facing a problem in converting matlab code into nios ide. is there anyway to convert these code into C/C++ used in nios ide? My matlab code is regarding image processing. is there any ...
18 years agoYou need to rewrite into C code your m-script code.
Did you use MATLAB functions like imfilter? In that case the work is harder, and it would be necessary to write this code in C. try using mcc -m 'your_file.m' in MATLAB
