16 years agoMatlab code to verilog
Hi there, Is there a compiler which can convert Matlab code directly in to VHDL/verilog format so to implement the code directly in to FPGA? I am trying to write codes on MATLAB and would like ...
16 years agoNo, it will not work.
To properly achieve what I was saying you will need to program your algorithm using exclusively simulink blocks, with no .m functions. You basically need to rethink all your code and make it parallel.
