16 years agoMatlab code to verilog
Hi there, Is there a compiler which can convert Matlab code directly in to VHDL/verilog format so to implement the code directly in to FPGA? I am trying to write codes on MATLAB and would like ...
16 years agoNo you do not need to learn VHDL nor Verilog. DSP builder does the job for you. Just use the library blocks that it provides and push the download buton.
