Melissa_M
6 years agoMatlab - Assertion failed! error - when calling alt_signaltap_run
I'm trying to capture data from the signal tap logic analyzer into Matlab. I'm using Quartus Prime standard 20.1 and Matlab R2020b. See attached image for the error. You can see I'm adding...
SyafieqS
6 years agoHi Melissa,
According to link below, some recommended Quartus version from Mathwork. Could you try to use Quartus Prime Standard 18.1 and Matlab R2020b together and see if it works ?
mathworks.com/help/supportpkg/alterafpgaboards/ug/supported-eda-tools-and-hardware.html
