Melissa_M
6 years agoMatlab - Assertion failed! error - when calling alt_signaltap_run
I'm trying to capture data from the signal tap logic analyzer into Matlab. I'm using Quartus Prime standard 20.1 and Matlab R2020b. See attached image for the error. You can see I'm adding...
SengKok_L_Intel
6 years agoHi,
Thank you for the reply, I understand that the KDB is NOT relevant. To confirm if this is the Matlab/Quartus version related, does the older Matlab version (R2010b or R2013a) works well with Quartus 20.1 standard version?
Regards -SK
- Melissa_M6 years ago
Unfortunately, I cannot get R2010b to work on my windows 10 machine. Matlab claims it is likely because Win 10 doesn't support any version below R2015. I did try running Quartus II 13.1 and Matlab R2020b, but that didn't work either. At this point, I don't know what more I can do.. Does this work for anyone?
