Melissa_M
6 years agoMatlab - Assertion failed! error - when calling alt_signaltap_run
I'm trying to capture data from the signal tap logic analyzer into Matlab. I'm using Quartus Prime standard 20.1 and Matlab R2020b. See attached image for the error. You can see I'm adding...
SengKok_L_Intel
6 years agoHi,
This is not required to have the DSP Builder for this case.
Does the KDB solution helpful to you?
Regards -SK
Melissa_M
6 years agoHi,
The KDB solution is confusing: I am using 20.1 and it's for Quartus 13.1. But I have no bin directory and no dsp_builder directory. It also refers to dspba and dsp_builder.bat, which I don't have, which is why I assumed it relies on dsp builder. How do I follow these steps in light of what I just described?
