Melissa_M
6 years agoMatlab - Assertion failed! error - when calling alt_signaltap_run
I'm trying to capture data from the signal tap logic analyzer into Matlab. I'm using Quartus Prime standard 20.1 and Matlab R2020b. See attached image for the error. You can see I'm adding...
SengKok_L_Intel
6 years agoHi,
To better assist you, could you please do let me know the following info?
- Are you using DSP BUILDER?
- Could you please refer to the following KDB solution if this is helpful? https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd05112014_135.html
Regards -SK Lim
- Melissa_M6 years ago
Hi, thanks for the reply.
I don't have DSP builder. Can I not read data from the signal tap without having the DSP builder blockset for matlab? Because I use to be able to do this with Quartus II 13.1 and Matlab R2010b.
