9 years agoMarvell 88EE1111 PHY tranciever MDIO reg configuration
I'm trying to troubleshoot PHY for my dual Ethernet design on the DE2-115 Cyclone IV board. (I have to load my *.elf file twice for some reason for my design to work). In trying to figure ou...
8 years ago --- Quote Start --- Is there any update on how to get the phy chips to work? --- Quote End --- What sort of system are you trying to create? I got it to work in VHDL using the Altera Tri Mode EMAC and 10/100 mode. If you are doing it some other way (eg via C code in a processor) that won't help much. Do you have the 88E1111 datasheet? If not, you need to get that from Marvell.
