agaripcan6223
6 years agoManual fitting with chipplanner
Hi, I want to generate metastability-based true random numbers using a model where 256 R - S latches are connected in parallel, as in Figure 1. For this, I have to place the NAND gates that make up e...
IDeyn
Contributor
6 years agoHi agaripcan6223 !
In order to create such a design you need to exploit hand placing the LUTs.
Have you tried using Assignments - Location -> LAB combinational cell?
Other issue is to create LUT mask to behave as NAND gate - you need to create hand placed LUTs and change their LUT mask using Resource property editor.
I also need to say that your design is highly unrecommended in FPGAs, here you create clock gating and combinational loops.
Ivan
