17 years agoMaking smart FIFO ?!
Hello all, First, I wish you an happy new year! I need some help. For my project, I need to store data coming from external memory (DDR2) to internal memory (MRAM or M4K blocks). I ha...
17 years agoSo if I have it right, only the first and last words are less than 256 bits? Everything else will be the correct size? How deep is the FIFO? If only 2 of the words aren't full, that's still pretty efficient on bit usage(unless it's extremely shallow). Or is this not correct? (FYI, after you reply I probably wont respond as I'm leaving on vacation. Good luck.)
