11 years ago
making of a 3 bit binary number from three individual 1 bit value.
i have three nos value like a , b and c. and each are 1 bit binary value. how i convert it into a three bit binary value where a is the most significant bit and c is the least significant bit and b is the middle bit. example: if a=1 , b=0 and c=1 then how i make it a three bit binary valu which containing as x[2..0] or x= value of [a b c]
    That's called concatenation......
    reg [2:0] x;
    assign x = {a,b,c};
    i work with fpga in block diagram environment not in hdl language.. so please u may suggest me the concatenation technique in block diagrame environment....
    You can name a wire something like x[2:0]
    Then the ones you want individually can then be named:
    x[0]
    x[1]
    x[2]
    And it should concatenate and associate them together at compile time.
    NOTE: You should NOT connect the wires together.
