14 years agoMaking a counter from 50MHz Clock?
Hi, I know this might be a really silly question but I can't seem to get the theory down into HDL: I want to make a 3579545Hz clock from a 50MHz clock input: i know that --- Quote Start...
14 years ago --- Quote Start --- You have it in NCOs hidden there. just use a suitable width adder starting from zero adding 3579545 every system clock and carrying over result after (50 million -1) i.e. if it becomes > (50 million-1) then subtract 50 million from it and keep going nonstop. Then MSB is your rate. The generated clock is correct rate-wise but duty cycle varies. --- Quote End --- so then:
if ((counter > 49,999,999) AND (counter < 3579545Hz))
counter = counter - 50,000,000
endif;
if(counter == 3579545Hz)
clk_enable <= "1"
else
clk_enable <= "0"
endif;
is that what i need to do? (not actual VHDL syntax :) )
