10 years agoLVDS vs Differential HSTL/SSTL
Hi All,
What's the difference between the LVDS vs Differential HSTL/SSTL pins? Are the both differential, aren't them? Thank you3 Replies
The termination required for the LVDS and differential hstl/sstl is also different. You can check the termination scheme in the device handbook IO chapter.
Just to add that dedicated differential buffer can run at faster speed as compare to two single ended buffers.
LVDS is generally using dedicated differential buffer. Differential HSTL/SSTL is using two single ended buffer with one inverted.
