14 years agoLVDS standard for PCIe Reference Clock pins
Hi, I am trying to connect my Cyclone IVGX FPGA (EP4CGX150CF23C7) with a TI multicore DSP via PCIe protocol using PCIe hard IP. According to cycloneIV handbook, the refernce clock pin standard ...
13 years ago --- Quote Start --- Hi, I am trying to connect my Cyclone IVGX FPGA (EP4CGX150CF23C7) with a TI multicore DSP via PCIe protocol using PCIe hard IP. According to cycloneIV handbook, the refernce clock pin standard is HCSL with differential dc coupling. 1) Can I use LVDS protocol with differential AC Coupling as shown in fig 1-27,28 in cyclone IV handbook volume 2? 2) Also, I am unable to find the voltage levels for HCSL standard. Any help? Thank you all for your time and effort. Regards. --- Quote End --- Hi, Did you find out if you can use LVDS for PCIe reference clocks. I'm having same trouble now and Alteras documentation does not give a clear answer. Please let me know if you found out something. -kramu
