11 years agoLVDS power requirement
I am kind of confused with the contents of this link. Can anyone help?:confused::confused::confused: https://www.altera.com/support/support-resources/knowledge-base/solutions/rd04282010_33.html
11 years agoHi Metaboy,
It is as the link mentioned, the differential voltage swing and the common mode should be your main concern instead of the voltage source. As long you Vpp of your IO meets the Vid of the device it should be fine.
