18 years agoLVDS I/O termination
Is an external 100Ohm resistor required at the input of an LVDS receiver I/O pair for the Cyclone III devices? The literature seems to suggest yes and no. Also, if I have "rx_in" as a single-channel ...
18 years agoI agree, that the requirement of external differential termination may be not that obvious.
However, there is a figure 8–2. typical lvds application, that shows the external termination. The verbose discussion of transmitter termination networks is necessary because of the different handling in row and column banks. If you are migrating from Cyclone or Cyclone II, you probably expect, that an external termination is necessary as with the predecessor, if you used Stratix before, you may expect an on-chip termination.
