12 years agoLVDS clock input issue and sdc understanding
Hi there, i'm working on a project with a Cyclon III (EP3C5), I'm continuing the project and some files are allready done, but it's high level user made and the creator is not available for qu...
12 years agothanks rbugalho,
now I have another problem with sdc file, my clock input of 200Mhz is not always available, so when it's not I would like to created from the USB clock (60Mhz). Cyclone III PLL does not support PLL with 2 inputs(60 & 200) for creating 1 output(200) so I try what you can see on the next image: so I divided in 2 cascade connected PLL, first I try was a MUX but I didn't know how to do the autoswitching when no 200M clock. https://www.alteraforum.com/forum/attachment.php?attachmentid=8146 I tried to use the timequest time wizard wich generate the next:
# Clock constraints
create_clock -name "CLK_USB" -period 16.667ns
create_clock -name "CLK_DIFF" -period 5.000ns
# Automatically constrain PLL and other generated clocks
derive_pll_clocks -create_base_clocks
# Automatically calculate clock uncertainty to jitter and other effects.
derive_clock_uncertainty
but I get the following clock warnings:
Warning (15055): PLL "SW_PLL:SW_PLL_inst|altpll:altpll_component|SW_PLL_altpll:auto_generated|pll1" input clock inclk is not fully compensated and may have reduced jitter performance because it is fed by a non-dedicated input
Info (15024): Input port INCLK of node "SW_PLL:SW_PLL_inst|altpll:altpll_component|SW_PLL_altpll:auto_generated|pll1" is driven by usbclk_pll:USB_CLK_pll|altpll:altpll_component|usbclk_pll_altpll:auto_generated|wire_pll1_clk~clkctrl which is OUTCLK output port of Clock control block type node usbclk_pll:USB_CLK_pll|altpll:altpll_component|usbclk_pll_altpll:auto_generated|wire_pll1_clk~clkctrl
why is not fed by a dedicated input? I understand that means clk is not using clk dedicated path. jitter is a problem for my purpose. Also, I would be interested to do sdc file manually like the one I posted first time, I've tried some modifications but I don't know how to declare the new PLL. I've been looking for sdc tutorial but they are really messy. Thanks,
