16 years ago
LUT holds final value for 2x clk cycles
Dear All,
I would like to ask for your help. I have produced a LUT 11 bits wide and 12 words in length. The values are a binary representation of a sine wave.
In my process i wish to continually step through the LUT writing each value to the output "Data".
The problem i have is that in my simulation "Data" retains the last LUT value for 2 clock cycles not 1.
I assume this is because when index = words a clock cycle is consumed setting index to zero and branching back to the IF clk = 1 statement.
ENTITY clkd_rom2 IS
 GENERIC (  bits : INTEGER := 11;
    words : INTEGER := 12);
 PORT (  clk : IN STD_LOGIC;
   data : OUT STD_LOGIC_VECTOR ( bits-1 DOWNTO 0));
END clkd_rom2;
ARCHITECTURE rom OF clkd_rom2 IS
 TYPE vector_array IS ARRAY (0 TO words-1) OF STD_LOGIC_VECTOR(bits-1 DOWNTO 0);
 CONSTANT memory : vector_array := ( "01000000000",
          "01100000000",
           --more values go here.......
          "00100000000");
BEGIN
 PROCESS (clk)
 VARIABLE index : INTEGER:=0;
 BEGIN
  IF clk='1' AND clk'EVENT THEN
   IF index < words THEN
    data<=memory(index);
    index := index + 1;
   ELSE
    index := 0;
   END IF;
  END IF;
 END PROCESS;
END rom;
Does anyone have any ideas how i can overcome this problem and loop back to the 0th index in my LUT without sacrificing a clock cycle.
I want to get the code working properly then i intend to use a much much larger ROM represenation of the sine wave possibly using a memory init. file.
Many thanks
Adrian.
PS i have .vhd and .vwf files.
    how simple, I am sure some would say obvious :)
    just tried that and it worked a treat.
    Thanks for your assistance pancake.
    Now i just need to try and get this simple design into the cyclone iii starter kit.
    wish me luck!!
    Thanks again.
    how about something like this?
        index := index + 1;
        if index = words then
          index := 0;
        end if;
       END IF;
      END IF;
