16 years agoLUT help!!!
I have wrote this code for implementing a neural network.What it does is to take some values(inputs) and some weights and computes the SUM(values*weigths).What i want to do is to check if the total s...
16 years agoOk i manage to do the first part of the project.What it does is :i insert some values for inputs(that will remain constants through all the process) and then when a clock EVENT i do this computation : input1*weight1+input2*weight2+input3*weight3.This is the multiply-accumulator unit.The second thing that i want to do(for which i need your help) is to compare this result(from the previous step) with a threshold and then fix the weight values in order to :
input1*weight1(new)+input2*weight2(new)+input3*weight3(new)>threshold.Here is my code library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; entity neuron is port ( in1,in2,in3,w1,w2,w3 : in unsigned (7 downto 0); clk : in std_logic; id : out bit; output : out unsigned (15 downto 0)); end neuron; architecture behavioral of neuron is type inputs is array (1 to 3) of unsigned (7 downto 0); type weights is array (1 to 3) of unsigned (7 downto 0); constant threshold : unsigned(15 downto 0):="0000011011100111"; constant sum : unsigned:="1"; begin process(clk,w1,w2,w3) variable weight : weights; variable input : inputs; variable prod,acc : unsigned (15 downto 0); begin if(clk'EVENT AND clk='1') then input(1):=in1; input(2):=in2; input(3):=in3; weight(1):=w1; weight(2):=w2; weight(3):=w3; acc:=(others=>'0'); end if; for j in 1 to 3 loop prod:=input(j)*weight(j); acc:=acc+prod; end loop; if(acc>threshold) then id<='1'; else id<='0'; end if; output<=acc; end process; end behavioral; I attached and a photo with the simulation results
