8 years agolpm functions and hdl
Hi all,
So I'm trying to create a (synchronous) 8-bit loadable counter, as below but for some reason this synthesizes to around 28 LE's compared to the altera LPM 11 LE version. Any idea why? Thanks! -Mux module register8 ( clk, clken, reset_n, data, load, cnt_en, updown, q, q_next ); input clk; input clken; input reset_n; input [7:0] data; input load; input cnt_en; input updown; output [7:0] q, q_next; reg [7:0] addsub; always @(*) if ( updown ) addsub = q - 8'd1; else addsub = q + 8'd1; // asynchronous 'next' value. This is used extensively for flags reg [7:0] q, q_next; always @(*) if ( load ) q_next = data; else begin if ( cnt_en ) q_next = addsub; else q_next = q; end always @(posedge clk or negedge reset_n ) if ( !reset_n ) q <= 8'd0; else if ( clken ) q <= q_next; endmodule12 Replies
Yes and no :-) If you choose an LPM_ADDSUB the cost for the lpm function goes to 16+ LE's whereas the counter comes in as 8LE's + 8LUT's. So what's the best way to synthesize and up/down counter without +/-? Anyone know?
-Mux - Altera_Forum
Hi ,
Most likely cause would be due to the use of the +/- operators. -Abr
