8 years agolpm functions and hdl
Hi all, So I'm trying to create a (synchronous) 8-bit loadable counter, as below but for some reason this synthesizes to around 28 LE's compared to the altera LPM 11 LE version. Any idea why? ...
8 years agoWe shouldn't question the OP's intentions: the OP may need the q_next to take some look-ahead decision.
Anyway; the original 28 LUTs can be reduced to 17 by rewriting the source code slightly:module register8 (
clk,
clken,
reset_n,
data,
load,
cnt_en,
updown,
q,
q_next
input clk;
input clken;
input reset_n;
input data;
input load;
input cnt_en;
input updown;
output q, q_next;
reg addsub;
always @(*)
if ( updown )
addsub = - 8'd1;
else
addsub = 8'd1;
// asynchronous 'next' value. This is used extensively for flags
reg q, q_next;
always @(*)
q_next = q + addsub;
always @(posedge clk or negedge reset_n )
if ( !reset_n )
q <= 8'd0;
else if ( clken & (load | cnt_en))
if (load )
q <= data;
else
q <= q_next;
endmodule This produces an (almost?) beautiful RTL schematic: https://alteraforum.com/forum/attachment.php?attachmentid=14923&stc=1 Oops, I did change the functionality after all ... Here is the corrected source code: module register8 ( clk,
clken,
reset_n,
data,
load,
cnt_en,
updown,
q,
q_next
input clk;
input clken;
input reset_n;
input data;
input load;
input cnt_en;
input updown;
output q, q_next;
reg addsub;
always @(*)
if ( updown )
addsub = - 8'd1;
else
addsub = 8'd1;
reg q, q_next;
always @(*)
if (load)
q_next = data;
else
if ( !reset_n )
q <= 8'd0;
else if ( clken & cnt_en)
q <= q_next;
endmodule and the corresponding (beautiful!) RTL schematic: https://alteraforum.com/forum/attachment.php?attachmentid=14924&stc=1 And still only 17 LEs! But it is still different from the original ... Three times is a charm ... module register8 ( clk,
clken,
reset_n,
data,
load,
cnt_en,
updown,
q,
q_next
input clk;
input clken;
input reset_n;
input data;
input load;
input cnt_en;
input updown;
output q, q_next;
reg addsub;
always @(*)
if ( cnt_en)
if (updown )
addsub = - 8'd1;
else
addsub = 8'd1;
else
addsub = 0;
reg q, q_next;
always @(*)
if (load)
q_next = data;
else
if ( !reset_n )
q <= 8'd0;
else if ( clken )
q <= q_next;
endmodule https://alteraforum.com/forum/attachment.php?attachmentid=14925&stc=1 And, I am lucky! Still only 17 LE. I must admit this starts looking obscure, so I will not get any brownie points :)
