14 years agoLPM_Divide Megafunction Timing Issues
Hey, I'm working with an Arria II GX. I've been having timing issues with the lpm_divide megafunction. I have created a divider using the MegaWizard Plug-In Manager that has a Numerator of 64...
14 years agoYou can use clock enable at your chosen rate. Assuming the core has clock enable port then you can apply multicycle of clock speed/enable speed.
You can also use logic generated clock and connect it to global lines.
