12 years agoLPM_ADD_SUB result right-shifted on Arria V
I created an lpm_add_sub megafunction using Quartus 13.1 to add two 16-bit unsigned numbers. In ModelSim, everything works as expected. I put X"0001" on both inputs and get X"0002". However once I tr...
12 years agoTHe LPM add sub is widely used and has been around for many years. I suspect it's more likely user error. Have you tried simulating your design?
can you post some code up for test.
