17 years agoLow Voltage Cyclone III Configuration
I'm doing a low voltage (1.8V) design and would like to find a configuration EEPROM to interface to my Cyclone III. Is such a part available?
17 years agoFrom the Stratix II GX pin connection guidelines:
--- Quote Start --- These pins are internally connected through a 5-kΩ resistor to GND. Do not leave these pins floating. When these pins are unused, connect them to GND. Depending on the configuration scheme used, these pins should be tied directly to VCCPD or GND. Refer to the Configuring Stratix II and Stratix II GX Devices chapter in volume 1 of the Configuration Handbook. If only JTAG configuration is used, connect these pins to ground. --- Quote End --- And from the Stratix II GX User's Guide: The configuration scheme is selected by driving the Stratix II or Stratix II GX device MSEL pins either high or low as shown in Table 13–1. --- Quote Start --- The MSEL pins are powered by the VCCIO power supply of the bank they reside in. The MSEL[3..0] pins have 9-kΩ internal pull-down resistors that are always active. During power-on reset (POR) and during reconfiguration, the MSEL pins have to be at LVTTL VIL and VIH levels to be considered a logic low and logic high. 1 To avoid any problems with detecting an incorrect configuration scheme, hard-wire the MSEL[] pins to VCCPD and GND, without any pull-up or pull-down resistors. Do not drive the MSEL[] pins by a microprocessor or another device. --- Quote End --- However, I did disregard this council somewhat as I wired them too a DIP switch that when closed pulled them directly to 3.3V and when open pulled them through 10K resistors to ground. Jake
