18 years agoLow Pass IIR filter using cyclone II FPGA
Hi everyone, I hava a task to implement low pass iir filter on cyclone II FPGA. The parameters of filter are the following: fp=5kHz; pass band frequency fs=8kHz; stop band frequency Fs=44k...
18 years agoIf you want more accurate filter response then i would suggest you to go for 32-bit representation of coefficients as per IEEE754 -Floating point Standard. You can use Floating point arithmetic unit core that altera provides to handle the Multiplications and additions in pipeline fashion to avoid latencies.
