18 years agoLow Pass IIR filter using cyclone II FPGA
Hi everyone, I hava a task to implement low pass iir filter on cyclone II FPGA. The parameters of filter are the following: fp=5kHz; pass band frequency fs=8kHz; stop band frequency Fs=44k...
18 years agoHi Koce,
this will depend also on the type of DAC that you are using. If you take care that your digital filter has a unity gain the digital output of the filter will have the same dynamic range of the filter input, which is the ADC output. So if you have a DAC that is capable of generating a [-5V,+5V] output you will be able to generate an analogue signal with the same voltage range, if you need it. Take care that most of the DACs are with current output and the output voltage range is determined by resistors tied to ground at the DAC output so you can choose your output swing with some freedom.
