18 years agoLow Pass IIR filter using cyclone II FPGA
Hi everyone, I hava a task to implement low pass iir filter on cyclone II FPGA. The parameters of filter are the following: fp=5kHz; pass band frequency fs=8kHz; stop band frequency Fs=44k...
18 years ago --- Quote Start --- So you have to analyze the output of your multiplier and see what dynamic range has its output (this will depend on the filter input and on the coefficients). --- Quote End --- I expect, that the filter should have a defined nominal gain rather than determining the gain empirically. That's also the concept behind using fractional number formats to my opinion: Having a defined filter function and choosing a signal and coefficient scaling from known signal characteristics. If filter blocks with a gain different from unity are cascaded, there is a danger of over- or underflow. It should be checked either with typical signals in a hand calculations or at best in a fixed point simulation. --- Quote Start --- If my output from FPGA must be 18bits wide how to threat 24 bits of multiplication result? I pick up just 18 LSBs? --- Quote End --- Using a fixed 6.12 scaling through the signal chain means discarding 6 high and 12 low bits after each multiplier. For the discarded high bits, a saturation logic should be used, including correct sign handling of course. Two additional points: A resolution of 12 fractional bits may be too low for the low frequency end of filter characteristics. It may also result in inacceptable high quantization noise at low input levels.
