AGaru1
6 years agoLow Latency 100G Ethernet Intel FPGA IP Hardware Design Example
Hi everyone, I want to create a loop between 2x Low Latency 100G Ethernet Intel FPGA IP Hardware Design Example on a Stratix 10 MX. The main idea is to implement the entire example design described ...
AGaru1
6 years agoThanks for your answer.
If i correctly understood i can use two Avalon Jtag master bridges, one for each Ethernet IP, as long as they have a different base address.
