14 years agoloss of icmp packets
Hi, I'm using iniche stack with "default" set-up ( I have not done any type of update/modification or similar). I've two thread : 1) one empty 2) second one stack standard init: ...
14 years agoHi,
point-to-point means: connection from PC to Nios with a ethernet cable, without ethernet hub/switch/router and via fixed IP address on both peer. When I said the PC was able to works inside LAN I said the PC had a DHCP client, antivirus SW (with automatic update) and maybe several service due to atoher application (e.g. outlook).So, the laptop could generate traffic and to congest the Iniche stack.It's only a idea.
