14 years agoloss of icmp packets
Hi, I'm using iniche stack with "default" set-up ( I have not done any type of update/modification or similar). I've two thread : 1) one empty 2) second one stack standard init: ...
14 years agoInstall a Ethernet scanner such as Wireshark to check out exactly what kind of packets go in and out of the PC.
Do you have any error messages written in the Nios console? Do you get those timeouts between good answers, or do you have only good answers first and then only timeouts after a certain point?
