14 years agoLoss of FPGA configuration
To minimize power consumption, I have the Oscillator input of the main part of my Stratix III design gated (glitchfree keeping low, if gated). Connected to this clock (50 MHz) are two synchron...
14 years ago> Did you try to stop the affected system parts, including the PLL with an asynchronous reset?
I replaced the clock gating by the reset (global_reset_n of DDR2 IP) as you indicated. On the board I'm currently working on, the error does not show up anymore. I even may gate the clock subsequently to the reset without any harm. However: I still observe significant power supply dip on VCCL(1.1V) and VCCPD (2.5V) when activating the reset (without clock gating), and I assume the POR did just not trigger (but may do so on another device...). Maybe I have some illegal bank voltage combination (did check that, but found no offending conditions so far)? ================================================= This is how my topology looks like (EP3SL50780): P28, CLK1p, Bank 1C, 3.3V : 50 MHz clock input to general PLL AH15, CLK5n, Bank 3C, 1.8V : Direct feed (here was the gate) from P28 A14, CLK13n, Bank 7C, 1.8V : Direct feed (here was the gate) from P28 Memory interface AB: AG15, CLK5p, Bank 3C, 1.8V : 50 MHz DDR PLL clock input (fed from AH15) Memory interface uses banks: 3A, 3C, 4A Memory interface CD: B14, CLK13p, Bank 7C, 1.8V : 50 MHz DDR PLL clock input (fed from A14) Memory interface uses banks: 7A, 7C, 8A PLL outputs of both memory interface are merged as indicated by AN462, most of the design is clocked with the merged phy_clk (200 MHz, fanout 17679). This is the clock I intend to stop for sleep mode. My general power supply concept looks like this: 1V1_VCCL : All 24 VCLL 1V1_VCC : All 8 VCC 1V1_VCCD1 : VCCD_PLL_B1 1V1_VCCD2 : VCCD_PLL_L2 1V1_VCCD3 : VCCD_PLL_R2 1V1_VCCD4 : VCCD_PLL_T1 1V8 . VCCIO1A/2A/3A/3C/4A/4C/5A/6A/7A/7C/8A/ 2V5 : VCC_CLKIN3C/4C/7C/8C VCCBAT VCCPD1A/2A/3A/3C/4A/4C/5A/5C/6A/6C/7A/7C/8A VCCIO5C/6C 2V5_VCCPT : All 8 VCCPT 2V5_A : VCCA_PLL_B1/L2/R2/T1 3V3 : All 2 VCCPGM VCCPD1C/2C/8C VCCIO8C
