14 years agoLoss of FPGA configuration
To minimize power consumption, I have the Oscillator input of the main part of my Stratix III design gated (glitchfree keeping low, if gated). Connected to this clock (50 MHz) are two synchron...
14 years agoThanks for sharing your thoughts. Out of these, I've got some further questions:
- In my setup, the CONFIGn is stable, therefor, I assume that POR is triggered. Which of the supply voltages that are monitored by POR would you expect to dipp assumed the PLL is "running wild"? - Are there other indicators to make out whether the PLL is the "bad" guy (I can not see the PLL output clock going mad)? - I use two synchronized DDR2 I/F with internal PLL, therefor, access to the PLL (to directly gate ate the clock output drivers) seems not trivial for me. Until now, I wasn't able to have external DDR2 PLL synchronized. Therefor, I intend to reduce the clock to a very low one instead of completely switching it off. May this be viable?
