15 years agoLoop index overflow problem
Hi there,
I've wrote a little VHDL program in Quartus II. I'd like to separate one big std_logic_vector into small fix-length std_logic_vectors and the compile told me that the index is out of range, very strange... source code: =================================================== load_p:process(i_clk,i_datain) variable p_count:integer range 0 to 8*8*i_width; --i_width is a constant variable p:std_logic_vector(i_width-1 downto 0);--buffer of one data begin p_count := 8*8*i_width-1; --counter for index for i in 0 to 63 loop p := datain(p_count downto p_count-i_width+1); --buffering (line 30) p_count := p_count-i_width; --get next line index end loop; end process; ======================================================= the compiler says: Error (10528): VHDL error at df_loader_p.vhd(30): value "-1" is outside the target constraint range (0 to 512) Help me out , thx!!!:(21 Replies
--- Quote Start --- very strange... --- Quote End --- The code does exactly what you have written. In the last iteration, it tries to decrement p_count from 7 to -1, although everything is finished. Instead of decrementing a variable, you may want to calculate the p_count value at the entry of each iteration.
