11 years agoLooking for state machine in verilog
Hello there, I'm running into the problem that I don't know how to do this. I want to write state machine to run 2 conditions on my project. When I turn on machine, I want it runs 1st cond...
11 years ago --- Quote Start --- I. A lot of old text books teams the two process method, but the apparent prefered method now is a single process. --- Quote End --- --- Quote Start --- Yes it does, and Im sure its how many started, but you can easily fall into the latch trap. As I understand the 2 process state machine is a throwback to very old compilers that could only cope with registers and logic in separate processes. But this hasnt been the case for a long time. For anyone starting, I would always recommend a single process (it reads better in my mind too - more like software!) To the OP - AFAIK, the same problems can also happen in verilog. So get googling. --- Quote End --- One-process state machines may seem to be the preferred method and will handle a lot of tasks but not all. Often you need combinatorial (non-registered) outputs and then the two-process is a lot easier to write and maintain than the 'one-process' where you have to anyway add that second process where you have to repeat most of the work to fabricate these combinatorial outputs. Most of my modules are ST-components for use in Qsys, and to handle the backpressure graciously you need combinatorial outputs. So Steffen, don't apologize. Two-process state machines are fine and certainly not out of fashion! Regards, Josy
