11 years agoLooking for state machine in verilog
Hello there, I'm running into the problem that I don't know how to do this. I want to write state machine to run 2 conditions on my project. When I turn on machine, I want it runs 1st cond...
11 years ago --- Quote Start --- You can achieve this by creating two processes (I don't know how this is called in verilog, I'm more into VHDL). The first process sets a pre-initialized signal from "State1" to "State2" if it gets a special signal from the second process. In the second process you put an if-statement like: --- Quote End --- I really dont know what you're on about (your post does not make a lot of sense). A lot of old text books teams the two process method, but the apparent prefered method now is a single process. to the OP: there are plenty of examples out there - did you try google yet?
