11 years agoLooking for state machine in verilog
Hello there, I'm running into the problem that I don't know how to do this. I want to write state machine to run 2 conditions on my project. When I turn on machine, I want it runs 1st cond...
11 years agoYou can achieve this by creating two processes (I don't know how this is called in verilog, I'm more into VHDL).
The first process sets a pre-initialized signal from "State1" to "State2" if it gets a special signal from the second process. In the second process you put an if-statement like:
State-Signal = State1
Switch-Signal = 0
Process1:
if (Switch-Signal = 1)
Set State-Signal to "State2"
Process2:
if (State-Signal = State1) then
Your code for State1
if (time is up)
Switch-Signal = 1
else
Your code for State2
this is a very raw example, how it is done normally. You can also use a switch-case-statement instead. You can also check if the time is up in process1 and then set state2 there.
