16 years agoLooking at gate signals inside a block
So the problem is that I have a top level block diagram and I can of course make pins and check the inputs and outputs of the blocks when I do the simulation after compiling the design and making a v...
16 years agoThe easiest way to do this is use HDL instead of block diagrams and use Modelsim - you have full access to monitor all signals.
