17 years agoLogic lock
How to make many logic locks that are exactly the same as one logic lock?
17 years ago --- Quote Start --- Should I export a logic lock containging an entity, then import 10 such logic locks, and then how to connect the ports of these 10 entities to other ports? --- Quote End --- Hi sylvest, what do wanted to achieve ? Do you have a module, 10 times used in your design. Do you have a lower level project for the module alone and you would like to import this into a top-level project ?
